There is no display window while opening HM. This error message is thrown. pls help. @tinh
Hi @Jouher
Try deleting the settings files from the working directory and .altiar folder form the temp directory,
I have deleted all folders from working directory. What you mean by temp folder? and why this could have happened? @Prakash Pagadala
Please see this link:
Hi i have deleted the folders. But, still problem exists.@Prakash Pagadala
Yes issue solved. Thanks. please could you tell the reason for this error
Not sure. Maybe some part of the program is corrupted or modified.
