Logic to Select nearby nodes (of shellmesh) to which hexa is projected? See the image.
Hi, Please help me to sort this issue.
I have created a vector using the above code. by createmark nodes 1 'by cylinder' option is selecting nodes of wrong component. Vector is created using two nodes shown in the figure by red arrow.
############################ # # Select Node of hexa to calculate # ############################
*createmarkpanel nodes 1 set nids [hm_getmark nodes 1]
############################ # # Select all Nodes of hexa # ############################ *createmark nodes 2 displayed set nd [hm_getmark nodes 2]
*createmark elements 1 displayed set eled [hm_getmark nodes 1] ############################ # # Calculate coordinates of hexa node selected # ############################ set x1 [hm_getentityvalue nodes $nids 'x' 0] set y1 [hm_getentityvalue nodes $nids 'y' 0] set z1 [hm_getentityvalue nodes $nids 'z' 0] *createmark nodes 1 {*}$nd hm_createmark elems 1 'by config' hex8 *createmark nodes 2 $nids set cln [hm_getclosestnode $x1 $y1 $z1 1 2] puts $cln
############################ # # Create Vector # ############################
set x2 [hm_getentityvalue nodes $cln 'x' 0] set y2 [hm_getentityvalue nodes $cln 'y' 0] set z2 [hm_getentityvalue nodes $cln 'z' 0]
*createmark nodes 1 'by cylinder' $x1 $y1 $z1 $x2 $y2 $z2 10 1 inside 0 1 0 *nodemarkaddtempmark 1 set cnd [hm_getmark nodes 1]
puts 'The selected node: $nids and Closest node: $cln' puts 'the nodes are $cnd'
