Good evening!
1. Could you please explain what does "function value" in Support Vector Table mean?
2. I know that for every attribute its weight w = sum_{i=1}^{i=N} (alpha_i * x_i).
It seems that the weight from Weight Table is equal to such sum, where alpha_i and x_i are values from Support Vector Table.
Why are the attrubute values x_i multiplied in this table on some coefficients? For example in the input example set the attribute "Outlook=rain" had values:
and in Support Vector Table this attribute has values:
| 0.0 |
| 0.0 |
| 0.0 |
| 1.3416407864998736 |
3. I tried to understand the meaning of alpha here:
https://www.quora.com/What-does-the-alpha-mean-in-the-dual-form-of-the-SVM-optimization-problem.
It is said: "if the positive training example has been correctly classified above the margin by the optimal w, the corresponding alpha = 0".
Is the converse true: if alpha = 0 then the positive training example has been correctly classified above the margin by the optimal w?
How can I use information about alpha values and support vectors to adjust the SVM operator and to get better performance?
Thank you very much for the help.
