Cannot connect rapidminer studio to rapidminer server
Robert_MacInnis
Robert_MacInnis New Altair Community Member
 I am trying to connect to a rapidminer server on another machine.  I am using version 7.6 of both products - which are working fine.
When I click on Create Repository I am only provided with two prompts Alias and Root Directory.
From the documentation it appears that my options should be: to include the http location of the server, server username, server password.
What are the steps I need to do in order to connect to reapidminer server (on another machine) from rapidminer
Best Answer
  • Robert_MacInnis
    Answer ✓
    Hi thank you for your very thorough reply.  The issue I was having was that on the last screen on your series, I was only seeing two prompts:  Alias and Root Directory.  Previosuly I had no problem until I installed RapidMiner 7.6
    I did a reinstall of Rapid 7.6 and followed the same steps and the last screen then showed the 4 prompts (including the http server location) and not the two as it did before.
    This can be closed.
    I very much appreciate your help though.
  • FBT
    FBT New Altair Community Member
    1. Click on the drop-down next to "Add Data" in the "Repository" panel
    2. Select "Create repository"
    3. Check the radio button "New RapidMiner Server repository" and click "Next"
    4. Enter your connection settings and click "Finish":
  • sgenzer
    sgenzer
    thank you @FBT for the great response with screenshots!
    Scott
  • Robert_MacInnis
    Answer ✓
    This can be closed.
