How can I createmark on a group of components, each having the same prefix (for ex. : floor_1, floor_2 and similarly)?
Rushabh Parikh
Rushabh Parikh Altair Community Member
edited January 2023 in Community Q&A
How can I createmark on a group of components, each having the same prefix (for ex. : floor_1, floor_2 and similarly)?  Currently I am able to create a list having the components with prefix floor. but when I am trying to create a mark using that list, HM is not marking any component.
set complst [hm_entitylist comps name]
set lst [lsearch -all -inline -glob $complst *Floor*]
*createmark comps 1 $lst
*assemblymodify somename 1 3
The ultimate objective is to have all the comps with same prefix into one assembly but when i debug I found the issue in "createmark" command.
Rushabh
  • Adriano_Koga
    Adriano_Koga
    edited January 2023
    Try this option under *createmark to select by prefix.
    But concerning your code specifically, you should run this using hm_createmark to work with a list, or puts your *createmark line between eval "*create......."
    Instead of:
    Use:
    eval "*createmark comps 1 $lst"
    or
    hm_createmark comps 1 $lst
