Hello I tried to create a circle surface in HM with spin option (start angle 0 and end angle 360) but it look like in the picture.
Please show me the solutions
Tks
Hello Pohan,
To create the a circular surface using spin option, you need to a rotate a line with a pivot point and the surface generated is controlled by angles.
Also, make sure your visualization is shaded.
Hi Pohan,
Please go through the recording below which shows creating circular surface using spin option.
Hi, but the problem is we still have a line starting from the center of the surface to one node
Then you can try creating circle with the Geom>>lines option. Provide the circle center and radius so that circle can be created and finally you can use spline option to create surface.
Thank George.
It worked!
