Hi
I Hypermesh, I use Tool/Mass calc to calculate the area of some components but I could not find the command for TCL.
Could you please explain me?
Thanks
You can use hm_getmass command.
Hi You can use hm_getmass command. Thanks
Thank you very much. By the way, do you know how to export this result to excel or text file?
Yes, please try following lines.
set fn [tk_getSaveFile -defaultextension csv]; set fh [open $fn w]; puts $fh 'Mass,Volume,Area'; *createmark elems 1 displayed; lassign [hm_getmass elems 1] mass volume area; puts $fh '${mass},${volume},${area}'; close $fh;
Thank you.
I tried this code but the elems could not be selected so I could not get the result. Could you please verify?
Pohan,
It works fine, please attach your model.
Thanks,
Imoto
