Hello
Could you please tell me how to change the normals of elements in RAD 0000 file? And can not file it in my RAD 0000 file for P14 property.
Thanks
For adjusting the normals, please go to the Normals Panel (Shift+F10) and adjust. We cannot change the normals from the _0000.rad file.
In Type 14 property we don't have an option for normals. If you want to check normals for solid elements create a skin element layer (Tools>Faces, create face for the solid component) and check the normals.
