Hi all,
I am new to tcl scripting
How can i read required data from .res file using tc lscripting
Thankyou in advance.
Hi all, I am new to tcl scripting How can i read required data from .res file using tc lscripting Thankyou in advance.
Dear,
I think .res file is a binary file
There is reference guide about how to read results using hmreslib.lib
looking for it in Hypermesh Help
hi tinh,
thank you for your response
not only .res fie sir any other output files like .out file or .op2 file
is there any separate keyword for reading those.will it be available in reference guide
regards
raj
I am not sure whether it is listed in reference guide
.out file seems to be a text file and you can parse it by tcl commands open, gets, ...
but .op2, .res files contains structured data and you need to look for their format definition
Alternative solution: open them in hyperview and use tcl to parse known data. There is reference guide about tcl classes used in hyperview
Hi tinh
i will check in hyperwprks guide and get back to you.
Thank you very much.
Hi tinh,
My requirement is I want to get 5 first order nodes of tetra elements for example (number will varies)nearest to the selected node.
But using hm_getclosestnode I am getting one node only.. is there any way to do this.
Please assist me to get solution.
Thnks
hi, add it to a mark to ignore in next search:
Set closest1 [hm_getclosestnode x y z]
*createmark nodes 1 $closest1
Set closest2 [hm_getclosestnode x y z 0 1]
*appendmark nodes 1 $closest2
Set closest3 ....
*appendmark...
thank you for ur suggestion.
While doing this it is considering 2nd order nodes also..but I want to ignore 2nd order node.(in tetra mesh)
And while appending it considering selected node also as nearest node.
thank you
Ok . To ignore mid node, switch all elems to 1st order
After found 5 nodes, switch elems to 2nd
Thank you very much ..i got with this.
I have a question ..reference I have is node number .with this node ..how to get a node in x direction on other side of component elements
Other end distance may varies in x direction.i want to get a perpenduclar opposite node to the selected node on the component outer surface elements.
Thank you.
You can select nodes on a direction by
*createmark nodes 'on plane'
Or 'by cylinder'
