Hi i was using the twitter api yesterday fine and now i can no longer get over 35 tweets through rapidminer?
Have twitter capped me or is this an issue with rapidminer?
You might have rate blocked yourself or your parameter for "recent or popular" might not have new tweets in it. Double check your parameter settings or try search for something different and see if the problem persists.
Hi Thomas
I have the same issue, when I search for trending strings for the day, I end up with 25 tweets when requested for 100.
Thanks
Vineet
hello @vineet_p_s - so as Thomas explained above, you are likely being throttled after exceeding your quota. Please see the Twitter API quotas here: https://dev.twitter.com/rest/public/rate-limits
Scott
