WPS Batch Jobs?
Best Answer
Hi Jim,
Here's a note about the batch command line of SLC/WPS on Windows:
https://community.altair.com/kb_view.do?sysparm_article=KB0120940
There's a similar note for Linux/Unix available if you need it.
(Please note that batch mode is only available for commercial licensees i.e. is not not available for 'Community Edition' users.)
Best Regards,
Nico1
Hi Jim,
Best Regards,
Nico1 -
Nico Chart_21517 said:
Hi Jim,
Best Regards,
NicoOK, thank you. I'll check that out. I'm using a commercial license, so this should be very helpful.
Jim
0 -
Hi Jim,
Best Regards,
NicoI’ve got WPS batch jobs working. It’s fairly simple (once you figure it out).
First, one needs to add the location of program wps.exe to the Windows PATH variable.
Second, one needs to execute in the directory containing the SAS program to be run (or fully qualify the program name by prepending the path).
Third, for a putative program named test_pgm.sas, one needs to run one of the below four command line strings. These are all basically same command except that I’m adding various components of date and time to the log file name. If no date and time are embedded in the log file name, the log will be overwritten each run.
- wps -stdio <test_pgm.sas >test_pgm.log -print test_pgm.lst 2>&1
- wps -stdio <test_pgm.sas >test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%.log -print test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%.lst 2>&1
- wps -stdio <test_pgm.sas >test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%_%time:~0,2%%time:~3,2%.log -print test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%_%time:~0,2%%time:~3,2%.lst 2>&1
- wps -stdio <test_pgm.sas >test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%_%time:~0,2%.%time:~3,2%.%time:~6,2%.log -print test_pgm_%date:~10,4%-%date:~4,2%-%date:~7,2%_%time:~0,2%.%time:~3,2%.%time:~6,2%.lst 2>&1
The following log files are, respectively, produced by each of the preceding commands:
1. test_pgm.log
2. test_pgm_2023-10-30.log
3. test_pgm_2023-10-30_2028.log
4. test_pgm_2023-10-30_20.28.46.log0
