Using a function with a changing input value within a loop
I'm trying to figure out why my macro is not being reset correctly within a loop.
I have a "Loop files." Inside that I have a Generate Macro->Generate Report->Add section.
- The Generate Macro creates a macro called "without_extension" with the function "replace(%{file_name},".tsv","")".
- The Generate Report creates an Excel file with report name: %{without_extension}
- The Add section adds to report name: %{without_extension}
I would expect, given three files in the directory being looped, three reports, each with one section added. I get the three reports. However, only one of the three has a section added. If I delete that one from the directory being looped, a different one has the section.
Please help me understand what I am doing wrong setting the macro.
Many thanks in advance.
1 - 4 of
41
1 - 1 of
11
Based on your explaination I think what's happening is that the the file is being overwritten each time the loop is finished. What you should do is name the report generated with the Loop Files macro %{file_name}. If the files that are being looped have unique file names then the reports will be generated with the filename.
