Hello Community,
I am trying to export an .inp file. I have tried to export solver, as show, however the file is not .inp
How do I create an .inp , not sure where i'm going wrong?
My attempt
Typical INP file
Thank you.
Maybe this's the limitation of Student release?
Someone of Altair can confirm that.
Maybe this's the limitation of Student release? Someone of Altair can confirm that.
Hi Nguyen,
I am using a commercial version.
I was able to rename the file and add an .INP extension. It is now showing as INP rather than FILE..
The next test in to see if it will solve.
Hi Nguyen, I am using a commercial version. I was able to rename the file and add an .INP extension. It is now showing as INP rather than FILE.. The next test in to see if it will solve.
Here's what I see in my release:
Looks like what I see
