Hi @Max Strahan !Sounds like you may need to verify the SQL Server credentials. Here's an example of the one we are using internally;Then you need to make sure that the Service Account has the right privileges to write to the database you are exporting it.------------------------------Baba MajekodunmiSolutions ConsultantAltair Engineering Inc.Manassas VA978-275-9325-------------------------------------------------------------------------Original Message:Sent: 02-05-2020 11:31 AMFrom: Max StrahanSubject: Error during export of visual processI'm currently trying to setup a visual process that has a database source connected to a workspace then 2 exports, however, it keeps failing on the export steps. Here's the error I keep receiving:The 'SQLNCLI11.1' provider is not registered on the local machine.Is it referring to my computer or the server and how do I go about fixing this issue?Thanks------------------------------Max StrahanSQL Developer------------------------------"
