How can I convert into a solid , is there anyway to check where the problem is.
I've exported a million of times as a solid from Enovia but when I import to Inspire is always like this like a surface so im not able to mesh or compute.
Hi Rui,
When you export from Enovia, what file format are you exporting the geometry as?
When exported as .x_t, .step, or .stl (to name a few), Inspire should recognize it as a solid body and be able to calculate the mass properties.
Hope this helps!
Adam Reid
Have you checked the model you imported with the Patch tool in the Geometry menu?
