After an FEA study is conducted I see several file types.
I know what INP is, I looking to identify the rest ?
HYP File -
MXD File -
RSP File-
INP File - input file, nodes, boundary conditions, material properties
ODB File -
Thank you
Are you running Abaqus? You should probably take a look at Abaqus documentation to understand what all these mean.
I know ODB files are the binary result files, with animation of your results (displacement, stress, ...)
Are you running Abaqus? You should probably take a look at Abaqus documentation to understand what all these mean. I know ODB files are the binary result files, with animation of your results (displacement, stress, ...)
yes, Abaqus solver within Hypermesh. That is a good idea. Thank you.
Nothing to see with Hyperworks/Hypermesh
