Hello All,
I am checking element quality, in this case equia. skew. The elements failing my setting are shown in white. Is there a way to automatically repair all elements at once, or do I have to go through each one ?
Thank you.
Bad elements come from "bad" geometry (small surfaces,...). So if you well prepare your surface, you got better quality.
Manual correction is possible, but this is the latest solution.
