Hi Iooking for metalic material for a tunnel to use in winprop to simulate a EM propagation at 5.8GHz in circular (diamiter 7m) tunnel with a metalic wall. is it possible to get that material model to import in the sdata base?
Thx
Mohamed
It is possible to add materials, including metal, in WallMan. Try the menu Edit / Materials, then the button Add Material.
I believe a generic metal is included in the materials database that is included with the WinProp examples, which can be found in the installation directory under \help. (C:\Program Files \ Altair \ 2020 \ help \ ).
