Dear all,
I am doing UNDEX simulation . In one of case I am using structure (Plate) as a solid element with following properties
and in other UNDEX simulation, I am using shell element with following properties,
but while comparing results it is observed that the deflection results from both the analysis (solid vs shell ) are different. The both results should show same deflection.
If anybody knows exact shell or solid properties to be use ,kindly provide valuable comments .
Thanking you
