<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.0.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.007-SNAPSHOT" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="6.0.007-SNAPSHOT" expanded="true" height="60" name="Retrieve toDo" width="90" x="45" y="30"> <parameter key="repository_entry" value="originalData"/> </operator> <operator activated="true" class="trim" compatibility="6.0.007-SNAPSHOT" expanded="true" height="76" name="Trim" width="90" x="178" y="30"/> <operator activated="true" class="replace" compatibility="6.0.007-SNAPSHOT" expanded="true" height="76" name="Replace comma" width="90" x="313" y="30"> <parameter key="attribute" value="nom"/> <parameter key="replace_what" value=","/> <parameter key="replace_by" value=" "/> </operator> <operator activated="true" class="replace" compatibility="6.0.007-SNAPSHOT" expanded="true" height="76" name="Replace hyphen" width="90" x="447" y="30"> <parameter key="replace_what" value="-"/> <parameter key="replace_by" value=" "/> </operator> <operator activated="true" class="replace" compatibility="6.0.007-SNAPSHOT" expanded="true" height="76" name="Replace whitespace" width="90" x="580" y="30"> <parameter key="attribute" value="nom"/> <parameter key="replace_what" value=" +"/> <parameter key="replace_by" value="_"/> </operator> <connect from_op="Retrieve toDo" from_port="output" to_op="Trim" to_port="example set input"/> <connect from_op="Trim" from_port="example set output" to_op="Replace comma" to_port="example set input"/> <connect from_op="Replace comma" from_port="example set output" to_op="Replace hyphen" to_port="example set input"/> <connect from_op="Replace hyphen" from_port="example set output" to_op="Replace whitespace" to_port="example set input"/> <connect from_op="Replace whitespace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
