I'm new to hypermesh and I have a simple question for you guys. Can we use a spring element to act like a real coil spring? In fact, I got an impactor hitting a dummy and in the real experiment, the impactor is stopped at a certain distance from it's initial position by a coil spring. I wanted to use a imposed displacement, but I need to keep the initial velocity to allow the impactor to slow down by transferring its energy to the dummy. So, I thought that maybe I can stop the impactor (which is rigidbody) by a spring element like it is in real experiment. Can I do that? Or is there something else I could do? So far, I wasn't able to use the spring correctly.
Thank you very much!
