I tried to delete the settings files for Hypermesh, but I probably did a mistake here. I don't see my Entity Editor window anymore (see picture). In fact, I can't, as I use to, edit my entity parameters. How can I get it back?
Thanks a lot!
JM
Make sure your solver user profile is correctly set, ok? For example, is it OptiStruct? Try changing to some other user profile and going back to OptiStruct.
Thanks! It was as simple as that!
