Hello, my question is the following:
How can I create a pressure penetration Interaction in Hyperworks 2022 Abaqus standard 2D.
This option is available in abaqus:
I do not how to create this interaction in Hyperworks.
Thank you,
If this interaction is not supported in the interface; I think you could create node sets of master and slave entities in HM. Then export as inp and add your input file these lines:
*Pressure Penetration, master=Solid_bolt-1.bolt_bottom, slave=Solid_plate-2.bolt-plate, penetration time=0.001_PickedSet80, _PickedSet79, 5., 20.
Check the abaqus interactions quide for more
