Good Day!
We have a product which contains PCB board with lot of components in it. Now we want to perform an analysis to find out the Displacement of the components in the PCB board when the sudden vibration is occurs. The sudden vibration due to our hand holds the product when we are in walking, running or jogging and carrying it into pocket. Also we want to perform the analysis for entire product, for now we want to perform only on pcb boards.
So I request you to help me to select which analysis should we perform and how to approach this model including meshing and model setup.
Is this analysis can be performed using Hyper mesh ? or please suggest me to which software should I use ?
Thanks & Regards,
Sivaprakash V
