Hi Good Afternoon,
I am trying to create a Moving Reference Frame in Hypermesh Cfd, But I can't do it.
I selected the surface or solid, then I select the axis ( surface center). One dialogue box which I want to enter the Angular velocity value, then scroll down it. Here in the X and Y, I need to put zero. If I put 0 in the X and Y, The axis would moved.
Here I attached the Screenshot, I faced a issue with it.
How to fix this issue?
Thanks & Regards,
Sivaprakash V.
