<operator activated="true" class="loop_examples" compatibility="5.3.007" expanded="true" height="76" name="Loop Examples" width="90" x="45" y="300"> <parameter key="iteration_macro" value="example_number"/> <process expanded="true"> <operator activated="true" class="extract_macro" compatibility="5.3.007" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="%{example_number}"/> <parameter key="statistics" value="count"/> <parameter key="attribute_name" value="metadata_file"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.007" expanded="true" height="60" name="Extract Macro (2)" width="90" x="179" y="30"> <parameter key="macro" value="%{file_name}"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="metadata_file"/> <parameter key="example_index" value="%{example_number}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="execute_process" compatibility="5.3.007" expanded="true" height="76" name="Execute Process" width="90" x="447" y="165"> <parameter key="process_location" value="Reporting"/> <parameter key="store_output" value="true"/> <parameter key="cache_process" value="false"/> <list key="macros"> <parameter key="file_name" value="%{file_name}"/> <parameter key="example_number" value="%{example_number}"/> </list> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Execute Process" to_port="input 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.007" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="reporting:generate_report" compatibility="5.3.000" expanded="true" height="76" name="Generate Report" width="90" x="45" y="30"> <parameter key="report_name" value="Datei %{file_name}"/> <parameter key="format" value="Excel"/> <parameter key="excel_output_file" value="C:\Datei %{file_name}.xls"/> </operator> <operator activated="true" class="reporting:report" compatibility="5.3.000" expanded="true" height="60" name="Report" width="90" x="179" y="30"> <parameter key="report_name" value="Datei %{file_name}"/> <parameter key="specified" value="true"/> <parameter key="reportable_type" value="Data Table"/> <parameter key="renderer_name" value="Data View"/> <list key="parameters"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="att_%{example_number}|id"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min_row" value="1"/> <parameter key="max_row" value="2147483647"/> </list> </operator> <connect from_port="input 1" to_op="Generate Report" to_port="through 1"/> <connect from_op="Generate Report" from_port="through 1" to_op="Report" to_port="reportable in"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
