I am using to Altair Hypermesh(optistruct) solver to perform Fatigue Analysis. I am a Beginner in fatigue Analysis.
 I want to define the Load Time History under TABFAT card. Now I am stuck in the Load Time history creating process.
 Actually software identifies what values in X column and Y column. ?
As per My knowledge, X is Time in seconds and what is Y , it is a scale factor of load or Actual. what we put in y column.
I assume two cases : Assume my actual Load is 500 N
Case 1: X (TIME in seconds)      Y(LOAD in N or KN)
                     0                      0
                     1                      1
                     2                      2
                     .                       3
                     .                       4
                     5                      5
                    6                      0
 Here I am used to created a load time history by using  scale Factor of the Load in the Y(Load) column.
 For Example : If I Given the force value as 500 N in the Working Model, then I enter the Scale factor of the Load as 1, 2, 3....respectively.
 Case 1: X (TIME )      Y(LOAD)
                     0                      0
                     1                      500
                     2                      1000
                     .                       1500
                     .                       2000
                     5                      2500
                     6                         0
 Here I am used to created a load time history by using Actual Load Y(Load) column.
 For Example : If I Given the force value as 500 N in the Working Model, then I enter the actual load in the upcoming Time (seconds).
Based on the Two assumptions which one is correct or Correct me if I am Wrong.
Thanks & Regards,
Sivaprakash V,
