<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="679" width="841"> <operator activated="true" class="read_csv" compatibility="5.3.000" expanded="true" height="60" name="Read CSV" width="90" x="112" y="75"> <parameter key="csv_file" value="C:\logs\fixedwidth.txt"/> <parameter key="column_separators" value=""\r\n""/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="windows-1252"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="text:generate_extract" compatibility="5.3.000" expanded="true" height="60" name="Generate Extract" width="90" x="246" y="75"> <parameter key="source_attribute" value="att1"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <list key="regular_expression_queries"> <parameter key="a1" value="(.{2})"/> <parameter key="a2" value="(?:.{2})(.{3})"/> <parameter key="a3" value="(?:.{5})(.{3})"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
AABBCCCCABCDBBDSABDBQBDDAASHHFGU
a1 a2 a3AA BBC CCCAB CDB BDSAB DBQ BDDAA SHH FGU
