Hyperworks for Pre Processing - Volume and Beam Meshing is missing the exercise 4 files for download. Is there another place on the website I can download them from?
You should be able to access here
https://learn.altair.com/local/altair_learning_plan/plan_overview.php?id=2
For some reason now when I try to go to the volume and beam meshing module, nothing will load. All I see is what is below.
MIght want to try clearing your cache and cookies on your browser.
I cleared the browser cache but no change. The other modules work for me. Just not volume and beam meshing.
I see no issue on my end, so I don't think it is the module itself.
You may want to try a different browser or a computer reboot.
I tried switching browsers and even tried my home wifi to see if it was a network issue but keep getting a blank page with nothing loading. The other modules work just fine.
Can you check if anything is getting blocked by your browser settings for this page?
Can you please try accessing it again? I believe something was reset for you on our side.
Hi Stephen! I'm following up on this issue. I'll get back to you soon. The problem is being fixed. In the meantime, you can look at the most recent version of this course that is now available in the LMS. Here's the link for you to follow: https://learn.altair.com/course/view.php?id=534
@Steven Wimberly Hi! Could you please try again and check if you can access to the Module?
