Hi experts,
I want to do the simulation when braking. I am using the Force entity to braking but the pad cannot work.
The results seem not the same as the reality. Please find the attachment to know my model
Thanks
Hi Brain,
The reason why the pads are not moving is due to the configuration of Joint 3 and 4. Since they are fixed to the ground body, they will not move. If you switch the configuration to InPlane joints and have the Orientation set to the Global Y vector. Run simulation, you will be able to see the pads move and come into contact with the rotor.
Best,
Christopher Fadanelli
Application Engineer - Multibody Dynamics
Troy, MI
Hi Brain, The reason why the pads are not moving is due to the configuration of Joint 3 and 4. Since they are fixed to the ground body, they will not move. If you switch the configuration to InPlane joints and have the Orientation set to the Global Y vector. Run simulation, you will be able to see the pads move and come into contact with the rotor. Best, Christopher Fadanelli Application Engineer - Multibody Dynamics Troy, MI
Hi @Christopher Fadanelli
I tried to change this, but my model cannot converge.
Hi @Christopher Fadanelli I tried to change this, but my model cannot converge. Thanks
A few notes.
You can update the step sizing. Since you are using 2022.3, go to the run settings -> Advanced Settings and increase the step sizing/tolerance.
The meshing on the rotor. There is an imprint of the pad on the rotor? The mesh is inconsistent and can lead to unreliable results, I suggest to update the meshing (to be flush and finer) on the flexbody and reimport it.
The pads should be converted to flexbodies to capture deformation. Having rigid bodies penetrate the rotor flexbody can also lead to errors.
See reference picture below.
Hi Brain, A few notes. You can update the step sizing. Since you are using 2022.3, go to the run settings -> Advanced Settings and increase the step sizing/tolerance. The meshing on the rotor. There is an imprint of the pad on the rotor? The mesh is inconsistent and can lead to unreliable results, I suggest to update the meshing (to be flush and finer) on the flexbody and reimport it. The pads should be converted to flexbodies to capture deformation. Having rigid bodies penetrate the rotor flexbody can also lead to errors. See reference picture below. Best, Christopher Fadanelli
I want to do a comparison between rigid-to-flex contact and flex-to-flex for this model.
I used the meshing from the OptiStruct model. I don't see the intersection between the pad and the rotor.
Hi @Christopher Fadanelli I want to do a comparison between rigid-to-flex contact and flex-to-flex for this model. I used the meshing from the OptiStruct model. I don't see the intersection between the pad and the rotor. Thanks
Sorry I should of been more clear on where the intersection is. During the simulation, the pads will be intersecting into the rotor (not at initialization). This can be a cause of the convergence issue. You can also alter the contact properties too. Is your OptiStruct model from Altair site or internally? If you hide the brake pad you can see the imprint.
