Hi everyone,
Can you help me? Why sprocket and chain cannot work?
Please see this model and video to know more about these errors.
Thanks.
Hello Brian - I notice a few issues with the model.
1) There are fixed joints connecting the links. The links should have a rotating dof between each other in order to make them move. For now, I recommend changing all those joints to Revolute.
2) There is no joint on the 30 teeth sprocket. it needs a pivot, likely a revolute, similar to the other sprocket.
3) One of the link is connected to the ground body. (Joint 59).
I would recommend to fix the above problems with the model. Deactivate the motion and see if you can get the chain rest on the sprockets purely under gravity.
Note that there will still be a few redundant constraints.
Good luck.
Regards
Praful
Hello Brian - I notice a few issues with the model. 1) There are fixed joints connecting the links. The links should have a rotating dof between each other in order to make them move. For now, I recommend changing all those joints to Revolute. 2) There is no joint on the 30 teeth sprocket. it needs a pivot, likely a revolute, similar to the other sprocket. 3) One of the link is connected to the ground body. (Joint 59). I would recommend to fix the above problems with the model. Deactivate the motion and see if you can get the chain rest on the sprockets purely under gravity. Note that there will still be a few redundant constraints. Good luck. Regards Praful
Hi Praful,
I have other questions:
Please see this model to know more about these errors.
Thanks
