Hi everyone,
When I did bearing length optimization, how to know bearing length after optimization for changing die and mandrel design.
Thanks.
Once the bearing length optimization is complete, the software generates the optimized bearing lines IGES file in the run folder. You can use those files.
ThanksChaitanya Logade
Hi Chaitanya,
I see that many IGES files but I only bearing group is optimized can import (some bearing group is fixed cannot import), right? we can use this optimized bearing for metal extrusion analysis?
hi, Is the last iges file created optimized?
