<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="521" width="955"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="id|a1|"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="series:differentiate_example_set" compatibility="5.2.000" expanded="true" height="76" name="Differentiate" width="90" x="313" y="75"> <parameter key="attribute_name" value="a1"/> <parameter key="change_mode" value="difference"/> <parameter key="lag" value="1"/> <parameter key="keep_original_attribute" value="true"/> </operator> <operator activated="true" class="series:lag_series" compatibility="5.2.000" expanded="true" height="76" name="Lag Series" width="90" x="447" y="75"> <list key="attributes"> <parameter key="a1" value="1"/> </list> </operator> <operator activated="true" class="rename" compatibility="5.2.006" expanded="true" height="76" name="Rename" width="90" x="581" y="75"> <parameter key="old_name" value="change(a1)"/> <parameter key="new_name" value="change_a1"/> <list key="rename_additional_attributes"> <parameter key="a1-1" value="lag_a1"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.006" expanded="true" height="76" name="Generate Attributes" width="90" x="715" y="75"> <list key="function_descriptions"> <parameter key="pcchange(a1)" value="change_a1/lag_a1"/> </list> <parameter key="use_standard_constants" value="true"/> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (2)" width="90" x="849" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="change_a1"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Differentiate" to_port="example set input"/> <connect from_op="Differentiate" from_port="example set output" to_op="Lag Series" to_port="example set input"/> <connect from_op="Lag Series" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true" height="521" width="882"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="|id|a2|a1"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="loop_attributes" compatibility="5.2.006" expanded="true" height="60" name="Loop Attributes" width="90" x="380" y="75"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="|a2|a1"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="iteration_macro" value="loop_attribute"/> <process expanded="true" height="575" width="992"> <operator activated="true" class="series:differentiate_example_set" compatibility="5.2.000" expanded="true" height="76" name="Differentiate" width="90" x="45" y="30"> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="change_mode" value="difference"/> <parameter key="lag" value="1"/> <parameter key="keep_original_attribute" value="true"/> </operator> <operator activated="true" class="series:lag_series" compatibility="5.2.000" expanded="true" height="76" name="Lag Series" width="90" x="179" y="75"> <list key="attributes"> <parameter key="%{loop_attribute}" value="1"/> </list> </operator> <operator activated="true" class="rename" compatibility="5.2.006" expanded="true" height="76" name="Rename" width="90" x="380" y="120"> <parameter key="old_name" value="change(%{loop_attribute})"/> <parameter key="new_name" value="change_%{loop_attribute}"/> <list key="rename_additional_attributes"> <parameter key="%{loop_attribute}-1" value="lag_%{loop_attribute}"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.006" expanded="true" height="76" name="Generate Attributes" width="90" x="514" y="120"> <list key="function_descriptions"> <parameter key="pcchange(%{loop_attribute})" value="change_%{loop_attribute}/lag_%{loop_attribute}"/> </list> <parameter key="use_standard_constants" value="true"/> <parameter key="keep_all" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.2.006" expanded="true" height="76" name="Select Attributes (2)" width="90" x="715" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="change_%{loop_attribute}"/> <parameter key="attributes" value="|change_%{loop_attribute}|lag_%{loop_attribute}"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="false"/> </operator> <connect from_port="example set" to_op="Differentiate" to_port="example set input"/> <connect from_op="Differentiate" from_port="example set output" to_op="Lag Series" to_port="example set input"/> <connect from_op="Lag Series" from_port="example set output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/> <connect from_op="Select Attributes (2)" from_port="example set output" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="161" width="547"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="set_macro" compatibility="5.2.003" expanded="true" height="76" name="Set Macro" width="90" x="179" y="30"> <parameter key="macro" value="last"/> <parameter key="value" value="1"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.003" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="313" y="30"> <list key="function_descriptions"> <parameter key="new" value="0"/> </list> </operator> <operator activated="true" class="loop_examples" compatibility="5.2.003" expanded="true" height="76" name="Loop Examples" width="90" x="447" y="30"> <process expanded="true" height="512" width="640"> <operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30"> <parameter key="macro" value="current"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.2.003" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="30"> <list key="function_descriptions"> <parameter key="result" value="%{current}/%{last}"/> </list> </operator> <operator activated="true" class="set_data" compatibility="5.2.003" expanded="true" height="76" name="Set Data" width="90" x="313" y="30"> <parameter key="example_index" value="%{example}"/> <parameter key="attribute_name" value="new"/> <parameter key="value" value="%{result}"/> <list key="additional_values"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.2.003" expanded="true" height="60" name="Extract Macro" width="90" x="447" y="30"> <parameter key="macro" value="last"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> </operator> <connect from_port="example set" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Extract Macro (2)" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Generate Attributes (2)" to_port="example set input"/> <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
