Hi everyone,
I met trouble when practicing tutorial MS-8600. Can you explain why it has this error?
Hi Pham - Which version are you using? I see in your screenshot you're using a MF-Tyre file. For this type of tire model, typically the test rig is run with a flat road (you can find this in the installation directory containing sample tire and road files). Can you repeat the test with the file shown below?
Hi Ananth,
I am using MV 2022, I am follow the tutorial MS-8600 and it give me the error as shown above . When we should use flat road, plank,... and so on?
Thank you.
Hi Pham,
Can you please use the TNO_PlankRoad_2D.rdf. You can find this file in <Altair Installation>\hwdesktop\hw\mdl\autoentities\properties\Tires\MF_SWIFT
or
add METHOD= '2D' in MODEL block as shown in image.
To know more about road files, please visit the following location
https://2022.help.altair.com/2022.1/hwdesktop/mv/topics/motionview/MFTyre-MFSwift_Help.pdf
Sonu
Hi Sonu,
Why TNO_PlankRoad.rdf isn't used? I ran the model and see that the results are different because of differences in the property of the road.
Thank you,
Tuan.
