<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.007"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.007" expanded="true" name="Process"> <process expanded="true" height="370" width="820"> <operator activated="true" class="text:create_document" compatibility="5.2.003" expanded="true" height="60" name="Create Document" width="90" x="45" y="75"> <parameter key="text" value="1.500,00"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.003" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="165"> <parameter key="text" value="567,00"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.003" expanded="true" height="60" name="Create Document (3)" width="90" x="45" y="255"> <parameter key="text" value="318,18"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.2.003" expanded="true" height="112" name="Documents to Data" width="90" x="313" y="120"> <parameter key="text_attribute" value="numbers"/> </operator> <operator activated="true" class="text_to_nominal" compatibility="5.2.007" expanded="true" height="76" name="Text to Nominal" width="90" x="514" y="120"/> <operator activated="true" class="parse_numbers" compatibility="5.2.007" expanded="true" height="76" name="Parse Numbers" width="90" x="648" y="120"> <parameter key="attribute" value="numbers"/> <parameter key="decimal_character" value=","/> <parameter key="grouped_digits" value="true"/> <parameter key="grouping_character" value="."/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Documents to Data" to_port="documents 2"/> <connect from_op="Create Document (3)" from_port="output" to_op="Documents to Data" to_port="documents 3"/> <connect from_op="Documents to Data" from_port="example set" to_op="Text to Nominal" to_port="example set input"/> <connect from_op="Text to Nominal" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
