Is it possible to (automatically) export a 'screenshot' or image of the modeled geometry when running flux in server mode?
Thanks and best regards,
Ruud
Hi Ruud,
No, it is not possible. When you are using Flux in batch (server mode) mode the graphic engine is not load.
You can export the result (and so the mesh) in H3D format in the scenario
Yann
