<Question regarding how to use Altair FEKO>
I used Feko to obtain RCS data at specific ranges of elevation and azimuth angles(actually almost all ranges). I divided the elevation angle from 0 degrees to 180 degrees in 1-degree increments, and for each elevation angle, I gathered RCS data from 0 to 360 degrees in azimuth.
 As a result, I obtained datas in polar coordinate form for the azimuth angles at all elevations as desired.
 The thing is, I would like to export each of these data points as a .dat file all at once.
 Exporting each Far Field shape individually for each elevation angle is cumbersome and time-consuming if done 181 times(you know, selecting degree - export .dat - naming file - again selecting another degree...).
 moreover, if I need to extend increments more densly, for example 0.1 degree, doing it all manually is infeasible.
 Is there a way to automate this process? I attach my cfx and pfx files.
 also I will shwo you Images. this is my Plane Wave Source Range.
 in posfeko, from 0 degree azimuth, all the way to...
 180 degree
 I also attach example .dat file of what I want to have.
