Hi All,
I have k file of 370 MB which includes segment pressure for ~0.1 million shell elements. As this is important part, I need small details also. So number of elements in my model is ~3.6 million. I am using 64 bit,16 GB ram, 4 core system. I have done modeling & set up using hypermesh. The model is running with no issues. My problem is when I opening this k file in a new HM (I am using HM2017), the file is not opening. If I delete the Load collector (Segment pres), It is opening properly.
Is this issue related to system requirements/ HM error? Also I have checked with LS PrePost in the same machine, it is opening properly. I am not sure what the issue is?
