The command shown below is correct for Ctrl + S = save mapping?
[. cget -menu].file invoke 2
Hi Udhay,
This command is to save the file as .hm.
Please find the attached image.
Thanks for your reply Johnson.
We can use the same command for mapping ctrl + S as save in hm. correct?
Insert the command as eval [[. cget -menu].file invoke 2] and try.
Please update
Ya, it's working..
Thanks George P Jhonson.
