*Expression('p2w2measure2.1.0.0.y') - what is meant by this expression in session file (.mvw)?
Also what is mean by u and v values in defining curve option?
could any one please explain these?
PFA screenshot for U & V vectors from help.
Hi Rahul,
Thanks for your reply.
Could you please explain the expression?
Also how to enter the values for curve?
Hi Udhay,
Please go through the attached document which explains about the expression stated above.
Also, please go through Help Menu on HyperView Expression Builder which explains more on this.
Hope this helps.
Hi George,
Thanks for your reply. I have got that details. Only details I need is Y option value (Since x should always 0). Consider I want to add x magnitude which is measured between 2 nodes. Measure id 3.. item index is 1(distance between), and what should be the Y option? Could you please expression for that.
e.g., p1w1measure3.1.0.0 (What is the value)
To Ragul,
Regarding entering values also, I have got the procedures and everything seems fine to me.
Is there anything about my query?
We are working on your query and will update you very soon.
