Is tcl script file is available to reset the default keyboard settings?
This procedure will rectify the Keyboard settings error. Thanks to George P Jhonson
1) Open HM.
2) Using command Window source the keycommandtable.tcl (script available in installation directory) or run the keycommandtable.tcl file in hm
3) Open keyboard settings.
4) Clear the Ctrl+s command that was entered earlier.
5) Hit “apply” and then “OK”
6) Then restart HM. This should be fixed.
