Is there any option in hyperview to visualize the components as per local coordinate system?
Hi @Udhay Rohith
Please use Resolved in: option in HV to plot results in local system
Hi Prakash,
Thanks for your reply.
Sorry for the late response.
Actually, I need to visualize the top view/front view of my assembly with respect to a user-defined coordinate system or local system. Is there any way to do that?
I do not know any way to use a local system.
But you can switch the view type to 'Lens' and then has much more options for input. For example, Target, Position, Orientation Method etc., see picture.
Best Regards,
Mario
Hi Udhay Rohith,
Change the Resolved in option to User system and select the local system you created.
Thank you
He isn't looking for tensor transformation of results...
See my post above.
<?xml version="1.0" encoding="UTF-8"?> Is there any option in hyperview to visualize the components as per local coordinate system?
@Udhay Rohith
Looks like this is customized.
Hi Mario & Premanand,
Thanks for your reply but I need an orthographic projection for a local system with simply clicking Front view/top view options. It will be useful in impact analyses.
Yes, It is customized for Hypermesh (Script). I got this script in Altair script exchange site. But I cannot able to find this kind of script for Hyperview.
Yeah, if there are any such, I will share with you.
