Hello everyone,
Is there any guideline as to how to mesh complex parts (e.g. engine block) which are not easily mappable? is there a procedure which will make it easy?
Bharat
Hello everyone, Is there any guideline as to how to mesh complex parts (e.g. engine block) which are not easily mappable? is there a procedure which will make it easy? Regards, Bharat
For complex geometry, hexa mesh maybe can not done.
The working procedure is rather simple:
Original Part => Split => Got splitted parts
Foreach splitted part {
If 'Mappable' then
OK
Else
Split & Check again
Endif
If you got unmappable part at the end, you can not do hexmesh with your initial part.
Hello Nguyen,
Thanks for the tip.
I guess i have a difficult task in hand.
Here're some ideas:
Thanks and regards
