Rubber and metal bonding
hiranwale_bharat
hiranwale_bharat Altair Community Member
Hello.
I have to simulate a model having Rubber and metal part rigidly bonded with each other with some chemical. While simulating the 3D model, do I have to create contact between rubber and metal parts or should I just maintain mesh connectivity between these two parts and assign different material properties to them?
Bharat
  • Altair Forum User
    Altair Forum User
    edited October 2015
    Hi Bharat,
    I would prefer having contacts between two if I am solving a non linear analysis.
  • hiranwale_bharat
    edited October 2015
    Hello Prakash,
    Thank you for the reply
    I have done free free modal analysis on a simple model with both conditions mentioned above in my query. And the results of both cases are matching upto 95%.
    Again a static analysis also showed pretty much same results in both conditions.
    So can you share your thoughts on it?
    Bharat
Welcome!
Welcome!
