I want to check optimized concrete wall size on a ground loaded with pressure. What material law from hyperworks can be used?
Tq.
What solver will you be using?
If you are using OptiStruct then use MAT1 with the appropriate values of E , nu and rho.
If you are using Radioss then use LAW 21or LAW 24 depending on type of concrete
In OS you can also use MATX21 but this will eventually convert to implicit analysis and run RADIOSS in the background.
Thankyou
