Is it possible quickly to fill hole in solid geometry?
See the below trick on closing solid holes using dimensioning
http://www.altairuniversity.com/wp-content/uploads/2013/11/Remove-holes-dimensionTTF.pdf
hI,
How can we do the holes filling in solids if I have many holes throughout the solid
Hi Gopal,
You can try with 41036 script available in Script Exchange,
This script allows you to organize and delete holes from geometry,
You can download the script from https://connect.altair.com/
See the below trick on closing solid holes using dimensioning http://www.altairuniversity.com/wp-content/uploads/2013/11/Remove-holes-dimensionTTF.pdf
good method!
