Hi, i have ansys results with lots of steps (different load), How to see animation goes through steps? I see that i can pick only one step.
Please set the animation to Transient Animation mode.
not working, only one step is animated all the time, i would like to see all step one by one
Use derived loadcases,
In Help See - HyperWorks Desktop Applications > HyperView > Results:
Derived Load Steps
HyperWorks Desktop Applications > HyperView > HyperView Tutorials > Result Data Analysis:
HV-3070: Creating Derived Loadsteps
Thank YOU!
one more thing, is it possible to save animation with movement? for example i would like to save gif with zoom, rotate etc.
Yes,
Go to view > toolbars > image capture to activate the image capture toolbar (if not already done so)
Then use the video camera icons, use capture graphics area for just the animation, the choose gif in save as type.
but if it is possible to move view during recording the animation?
this may not be possible within HyperView, you will have to use third party software for that.
Instead of recording video using hyperview. Simply open any blank power point presentation & select option video recording. Then open hyperview, it will autmatically start recording the animation & record until you stop that. It is the best way to capture video in hyperview.
