Hi, when i mask some elements, nodes left, and I have problem with picking nodes of elements which are active. How hide that nodes? It is HyperMesh 14.0.
Hide the groups and constrained extra node using model browser.
Sometimes I have the same problem. I have to go out completly the current panel to continue without issue.
I think v14.0 has some graphic bugs.
unfortunately not working, it is only thetra meshing, no extra nodes or groups, when i hide it, nodes left..... not visible, but can pick them...
Check Graphic driver details.When you have updated Graphic driver?
Using DXDIAG you could get graphic card details.
i updated it, becouse of wrong element visualisation, now all is ok, only that flying (not visible) nodes
Sometimes I have the same problem. I have to go out completly the current panel to continue without issue. I think v14.0 has some graphic bugs.
what do you mean about 'go out to current panel'?
please answer, becouse of that problem i cant work...
are you facing this problem with one model or is happening for all model?Could you share some sample file to check this issue?
Go out of Current panel means simply exit from any operation i believe.
