Hi, is it possible to see BF_TEMP - temperature from Ansys in HyperView... i couldnt find it
regardsJakub
Hi jakub.ziontek,
could you please let me know what is the version of HyperView and Ansys are you using?
what is the type of analysis you have done using Ansys?
Do you see temperature under result type under HyperView?
We support temperature plot for thermal loads.
Please Note: If you are a commercial customer, you can contact your local support for a script that will help you do the same @ http://www.altairhyp...ortProduct.aspx
It is structural analysis. I cant find applied temepratures (as body force) in hyperview. It is hv v12.0.
