hi
i was changing thetra elements 1st order to 2nd order, and after it midnodes are disorded, could anyone explain why?
regardsJakub
hii was changing thetra elements 1st order to 2nd order, and after it midnodes are disorded, could anyone explain why? regardsJakub
regards
Jakub
What do you mean 'disorded' ?
i wanted to keep thetra mesh the same, only mid nodes added, but after change to 2nd order. midnodes are not in line between main nodes.
Hi
I think you switch the option to 'midnode projected to surf' so they are distored
change to 1st, then change again to 2nd with 'mid node exactly mid point'
